Home Forums Products Rackmount H8000FW “Initializing” problem Reply To: H8000FW “Initializing” problem
#141204
    Clearly you have a hardware problem. This capacitor could fail for one of the following reasons:
    1) Random failure
    2) Installed backwards
    3) Over-voltage.
    Either way, it is connected across the main power supply and may have caused damage. Not possible to say from a distance. You could check for the following voltages:
    1) about 20V (rough) across the replaced cap.
    2) 5V at TP1507
    3) 8V across C1520
    4) 15V across C1514
    If these are not all there there is a big problem. Either way, it may need to come in for sevice.
