Home › Forums › Products › Rackmount › New Orville owner, have a few questions! › Reply To: New Orville owner, have a few questions!
#141417
nickrose wrote:
Sounds like you may need a tech-y friend ..
Definitely!
If you get noise or distortion, check the meters. Also, try adjusting Orville’s output level – you may be overloading whatever you are feeding.
Ok, will check this out tonight.
If, as appears, you are only connecting one channel, you’ll only get activity on one of the meters.
Yes, only 1 channel currently. Even still, I am getting no display on any meter. Maybe the output is too low to register?
Thanks Nick
Kevin
