Home Forums Products Rackmount New Orville owner, have a few questions! Reply To: New Orville owner, have a few questions!
#141425
nickrose wrote:
You need to initialize the unit (see UM).
Thereafter, you need to set up the levels so that loud signals at least go into the yellows. Some presets need a good signal level. Also, you will get noise or distortion if the levels are wrong.
Ok, looked through the manual last night, I did not see Re-initializing the unit in there. I see a section talking about clear setup to return to factory defaults, is this what I need to do or is there something more extensive?
