Home Forums Products Rackmount Gain matching on Eclipse Reply To: Gain matching on Eclipse
#141807
simeon
    one trick you can do…instead of bypassing the unit, create a blank preset with the overall gain set to -3db and then select that preset when you want no effects. you can use midi mapping if you need to
