Home › Forums › Products › Rackmount › Eventide GTR4000 expression pedal problem › Reply To: Eventide GTR4000 expression pedal problem
July 25, 2016 at 10:21 pm
#143927
Thanks for your quick reply. I do have the TRS cable in the pedal jack. I can see why you might think it was in the footswitch because the expressioin pedal was changing programs when depressed. I didn’t command the foot pedal input to do anything before it started changing programs. I will try plugging it in without the expressioinator and clear the internal memory. Hopefully this will do the trick.
Best Regards,
Will Webster
