Home Forums Products Rackmount DSP4500 / Problem in Internal RAM Reply To: DSP4500 / Problem in Internal RAM
#144385
After booting up Logic X and testing the 4500 through the whole set up again
the 4500 boots, gives the error message – “problem in 4500 presets – bad checksum
but then gives the “continue” button to push.
ordinarily in the case I could push the continue button
and at least the presets worked
now a new situation
There is no sound signal or sign of any sound moving the meters on the 4500
I do see one very important reason for this
I have the Eventide routed through the back of TC Electronic Ex. soundcard
using sp/dif cables..and set up for this in the TC panel
On Logic I have them routed through the channels 15 and 16
it usualy shows up saying “15 – small room- (4s snare chamber ) and 16 Large Room (3.9 Prince Large Hall )
I notice that the channel 16 large room (3/9 Prince Large Hall ) does not appear in the menu..only channel 15
First thoughts are this might be a problem in the cable even
Nteh question is could something have happened  after “pushing the “8” button to “clear all”
or maybe the problem is in the Eventide…In any case if you have any further suggestions on this I would greatly appreciate it
any suggestions will narrow down where to isolate the problem
so that at least i can tell a repaier man what your analysis is. Many thanks once again!
j Bell
