Home › Forums › Products › Rackmount › H8000 / 4 TRACKER #4 (preset 735) question › Reply To: H8000 / 4 TRACKER #4 (preset 735) question
#144581
    To do it from the front panel, you need to use the Patch Editor, which is described in the separate Programmer's Manual.
    In simple terms:
    1) Load the preset
    2) Press and hold PARAMETER to enter the Patch Editor.
    3) Press the right arrow key until you see "pitchshift2" in the top right.
    4) Hit <modify>
    5) Hit the down arrow until you highlight "shift:pitch1-out".
    6) turn the wheel slightly so it changes to"shift:pitch2-out".
    7) Press SELECT to accept.
    8) Press <done> to exit modify.
    9) Repeat steps (3) to (8) to set pitchshift3 shift to pitch3-out and pitchshift4 shift to pitch4-out
    10) Hit PROGRAM to exit the Patch Editor and SAVE THE PRESET.
