Home Forums Products Rackmount 7600 external pedal control messing up other effects Reply To: 7600 external pedal control messing up other effects
#145491
    You don't say which effects have this problem. A number of effects will have a default external modulator connection ("assign") which may default to the pedal – you should probably check this, and if necessary use a different "assign" for your feedback input.
    Look in the UM under "The Concept Behind "Redirection" – External Assigns 1-8 and Trigs 1 & 2" for more info on "assigns."
