Home › Forums › Products › Rackmount › 7600 external pedal control messing up other effects › Reply To: 7600 external pedal control messing up other effects
#145610
I renamed the effect but it is a Delay with LFO’s     On the mixer page first info dispay highlighted area and set up pedal modulation the parameter is dely repeat.   and it is screwing up all my effects I can set the parameters correctly update them then it goes haywire for some reason the highlighted area is what gets thron off and it is the first row usually delay time or repeat
