Home › Forums › Products › Rackmount › 7600 external pedal control messing up other effects › Reply To: 7600 external pedal control messing up other effects
January 28, 2017 at 4:04 pm
#145626
The pedal modulation is global via the "Assigns", so it will control whatever effects that use that "assign." If I understand you, one approach to consider would be to use one of the higher numbered assigns, which are unlikely to be used by any preset, for the pedal, and make sure it is not configured for any of the other ones.
