Home › Forums › Products › Rackmount › H8000 as whammy pedal › Reply To: H8000 as whammy pedal
#145761
MFPhouse
    … i had the same Problem here. But i fixed it.
    I feel better with cabling the controller in Vsig direct instead of via ” hold select “.
    I build some Presets where 5 Pedals ( via CV – CC ) controlled parameters and now it works. What kind of Pedals do you use ? Some times there is a translation problem in between the Midi 127 value ( fix ) and ” your ” Value.
    nickrose wrote:
    The H8000 was designed as a studio device rather than a live performance instrument,
    you are kidding wink…i bought this Maschine because this is the only Unit wich can do thinks like that in realtime.
