Home › Forums › Products › Rackmount › Guitar string bend with H7600 diatonic harmonizer not working › Reply To: Guitar string bend with H7600 diatonic harmonizer not working
#145895
wedelich
    j20056 wrote:
    I really like the Diatonic Shifter preset, and use it successfully in 3rds in various scales and modes. However, it doesn't seem to have any ability to handle string bends. For example, if I do a half step bend, the 3rd note generated by the patch stays "flat" and doesn't follow the bend until I have reached the half step, or even full step, at which points it shifts by a whole half step. I assume this is because the algorithm breaks the frequency spectrum into discrete bands and only checks which band a given note is instead of doing so but then applying the correct frequency shift ratio to the bent note. I'm sure the algorithm is slightly more complex but not really. Is there a better H7600 patch that can do that or too complex?
    Depending on which preset you're using (which one btw?) there should be a quantization control under the CAL tab. Turning this down to 0% should allow for string bends.  Let us know if that doesn't work for you.
