Home › Forums › Products › Rackmount › Guitar string bend with H7600 diatonic harmonizer not working
March 9, 2017 at 5:26 pm #145895
wedelich
ModeratorEventide Staffj20056 wrote:I really like the Diatonic Shifter preset, and use it successfully in 3rds in various scales and modes. However, it doesn't seem to have any ability to handle string bends. For example, if I do a half step bend, the 3rd note generated by the patch stays "flat" and doesn't follow the bend until I have reached the half step, or even full step, at which points it shifts by a whole half step. I assume this is because the algorithm breaks the frequency spectrum into discrete bands and only checks which band a given note is instead of doing so but then applying the correct frequency shift ratio to the bent note. I'm sure the algorithm is slightly more complex but not really. Is there a better H7600 patch that can do that or too complex?Depending on which preset you're using (which one btw?) there should be a quantization control under the CAL tab. Turning this down to 0% should allow for string bends. Let us know if that doesn't work for you.
March 9, 2017 at 10:36 pm #114052
J20056
ParticipantI really like the Diatonic Shifter preset, and use it successfully in 3rds in various scales and modes. However, it doesn’t seem to have any ability to handle string bends. For example, if I do a half step bend, the 3rd note generated by the patch stays “flat” and doesn’t follow the bend until I have reached the half step, or even full step, at which points it shifts by a whole half step. I assume this is because the algorithm breaks the frequency spectrum into discrete bands and only checks which band a given note is instead of doing so but then applying the correct frequency shift ratio to the bent note.
I’m sure the algorithm is slightly more complex but not really.
Is there a better H7600 patch that can do that or too complex? -
March 11, 2017 at 3:33 am #145918
J20056
ParticipantThanks it worked perfectly. I use DiatonicShift.
So now I have to ask, what does the quantize parameter do, and do I lose quality or else? It sounds great, so I’m happy but just curious.
March 13, 2017 at 3:59 pm #145926
wedelich
ModeratorEventide StaffJ20056 wrote:Thanks it worked perfectly. I use DiatonicShift.
So now I have to ask, what does the quantize parameter do, and do I lose quality or else? It sounds great, so I'm happy but just curious.
Glad that worked for you! The quantize is basically just doing auto-tune. It's forcing all the pitchshifting to increasingly hard quantize to the intervals deteremined by the key and scale.
