Home Forums Products Rackmount Eclipse problem Reply To: Eclipse problem
#146435
Jan Geerts
    The Reset did the trick, thanks.
    I do wonder how to set it up with two combos though.  So, I go from the main outs with jack cables to the input of the combos.  If I keep the levels at unity in the Eclipse, it is a huge boost.  Wasn’t there a 6db attenuation on the jack outputs?
    Also, I set the wet/dry ratio to 50/50, but then I can’t use the distortions or the ambient sounds that would need to eliminate the dry signal.  How is it best set up with 2 combo’s (Tweed Deluxe and Bassman)?
    thanks
    Jan
