Home › Forums › Products › Rackmount › Eclipse expression pedal problem › Reply To: Eclipse expression pedal problem
Ok I’ve had this problem of expression pedals behaving badly with the eclipse. HERE’S HOW IT’S DONE!
Go to patch say “288 delays+verbs”
Click “parameters” twice. Then click “Levels”
To assign expression pedal you want it to assign to FXA MIX, and NOT! FX! LEVEL! Leave FX level at 0.0dB. Hold soft key down on fx mix then…..
(You’re now in the modulate section which is where you can assign expression pedal and more)
Click
On your midi pedal you can now choose how little fx you want in heel position and how much in toe position (0-127) so when you switch to new patch it will listen to your expression pedal position. And that’s the while point!
Use the GLOBAL fx mix to taste. Mine is set to 40% on patch 288, which is a lot.
You’re welcome.
