Home › Forums › Products › Rackmount › Syncing H8000FW to ext Midiclock › Reply To: Syncing H8000FW to ext Midiclock
May 29, 2017 at 2:29 pm
#146532
The input range is deliberately limited to avoid unlikely values. You may disagree with this, but it is not a bug.
You could argue that there is a minor inconsistency between the input and output ranges, but the output value does have to be explicitly set, whereas the input could be anything.
