Home Forums Products Rackmount Eclipse + H9 tap tempo with groundcontrol Reply To: Eclipse + H9 tap tempo with groundcontrol
#146567
    Looks like you are not sending Eclipse the CC that you think you are.
    It is also possible that the external you picked is connected to a level parameter – try a different (suggest high numbered) external.
    Can't help with the multi channel issue- this would be a question for GroundControl.
