Home › Forums › Products › Rackmount › Eventide H9000 › Reply To: Eventide H9000
July 24, 2017 at 7:33 pm
#146844
SkyWriter wrote:
ARM? Too bad you can't just write the app for the iPad's ARM and skip the NRE of building hardware.
AAgnello wrote:
We're working on making that possible. We've created a system to confirm that the H8000 presets behave and sound the same when running on the H9000. So far, the majority test OK but there are still some that need work. The challenge comes from the fact that the H8000 is based on a fixed point DSP chip while the H9000 is ARM based. The H9000 is still a work-in-progress.
The H9000 will hold up to 4 quad-core ARMs so that it can run 16 H8000-class algorithms simultaneously.
