Home › Forums › Products › Rackmount › Eventide GTR4000 expression pedal problem › Reply To: Eventide GTR4000 expression pedal problem
September 4, 2017 at 2:56 am
#147099
I am currently using a Boss FS-6 with my gtr4000 and it seems to be communicating well with the unit. However, I am having trouble programming the signals correctly. All I want to use the switch for at this point is to bypass the unit. It seems like the commands from the footswitch are cycling through the tip and ring settings and I end up having to hold the momentary switch down to keep audio on and I have to press the footswitch a couple times to get to bypass. Anybody know how to make the footswitch input perform solely as a bypass?
Thanks,
Will
