Home Forums Products Rackmount Eclipse expression pedal status Reply To: Eclipse expression pedal status
#147594
depressor
    nickrose wrote:
    Sorry – no obvious solution. Our goal is that a loaded preset sound the same as when it was saved it (for hopefully obvious reasons).
    In many cases, the EXP pedal will not be in the same position, but we still want it to sound the same. So, you have to move the pedal for its state to be recognized.
    Yes I understand it, but  the Eclipse is a professional unit, it should have a parameter that turns on/off the expression pedal status reading. It is very useful in some presets.
