Eclipse expression pedal status
Home Forums Products Rackmount Eclipse expression pedal status
    • #114449
      depressor
        Does the Eclipse immediately read the expression pedal stauts when I change the preset? When I change the preset, It seems that I have to move my espression pedal before it works correctly. I need that the Eclipse could read my expression pedal position before moving it.
        Can you help me?
        Thanks
      • #147591
          Sorry – no obvious solution. Our goal is that a loaded preset sound the same as when it was saved it (for hopefully obvious reasons).
          In many cases, the EXP pedal will not be in the same position, but we still want it to sound the same. So, you have to move the pedal for its state to be recognized.
          • #147594
            depressor
              Yes I understand it, but  the Eclipse is a professional unit, it should have a parameter that turns on/off the expression pedal status reading. It is very useful in some presets.
