Home Forums Products Rackmount Eclipse checksum errors Reply To: Eclipse checksum errors
#147815
ZebKwijibo
    nickrose wrote:
    ZebKwijibo wrote:
    A bit desperate…
    You don't say, but I assume you are using the FIX command when this happens.
    You could try another battery, but if this does not work, it points to a hardware problem. Sorry.
    First, thanks for your reply!
    I’ve already tried some other batteries and even checked them with a multimeter and yes I went through the ” fix” procedure and everything fails… Except the checksum error message my eclipse is working well with no strange behaviors
    Do you know what kind of hardware problem it could be?
