Home Forums Products Rackmount Eclipse checksum errors Reply To: Eclipse checksum errors
#147819
    ZebKwijibo wrote:
    Do you know what kind of hardware problem it could be?
    I would guess that either the battery backed up ram is not being shut down properly, or it is taking too much current and running down the battery.
    You can check the second by measuring the battery voltage in circuit and then again a few days later. There should be no meaningful change.
