Home › Forums › Products › Rackmount › H3000D/SX to guitar rig › Reply To: H3000D/SX to guitar rig
February 6, 2018 at 8:20 pm
#148349
cc51503 wrote:
Hope I can help. I have a dsx running in the loop of my peavey 5150II head with great results. My loop is -10db so I had to switch out two jumpers in the unit to change it from line level to -10db this will depend on your amps loop.. As far as the cables just use three pin xlr to unbalanced 1/4. Rewire pin three as the hot pin and pin two as cold …..swap the two in other words….and thats it. Mine sounds excellent……gets a strong input signal as it should.
Hi. I sure hope you get this message all these years later.:D
It seems like what you did, is going from 6 wires from the two xlr outputs to 4 on the TS side. Am I right?
I am guessing you did that on the input side also. Is that couple in the picture a stereo one? I’m trying to rig up a cable like yours. Want to make sure I don’t screw up anything.
