Home › Forums › Products › Rackmount › Eventide H9000 › Reply To: Eventide H9000
February 19, 2018 at 1:45 pm
#148473
AAgnello wrote:
We’re working on making that possible. We’ve created a system to confirm that the H8000 presets behave and sound the same when running on the H9000. So far, the majority test OK but there are still some that need work. The challenge comes from the fact that the H8000 is based on a fixed point DSP chip while the H9000 is ARM based. The H9000 is still a work-in-progress.
As part of your evaluation and porting, are you fixing bugs in the original H8000 programs as you come across them? (I know for example the vocoders are pretty much broken and looking through the H8000 threads you’ll find other examples of presets that just don’t work as intended).
thanks
