Home Forums Products Rackmount Eventide H9000 Reply To: Eventide H9000
#148524
cbm
    jbamberg wrote:
    The maximum for each longdelay module is 120 seconds (as I believe it was in the H8000). I think you could probably manage to use up all the RAM if you had a lot of longdelays and you were running at 96kHz but that would take some effort.
    Orville / H8000 longdelay max was 174 seconds of Sampler Memory, FWIW.
    I largely use my Orville as a looping machine, so I would hope that the H9000 longdelay max can eventually be expanded to match the Orville / H8000.
