Home › Forums › Products › Rackmount › Eventide H9000 › Reply To: Eventide H9000
#148780
KazRemark
    All of this complaining is beyond silly. I’ve been using a DSP-7000 for the last 15 years or so, I bought it used back then because I couldn’t afford the new prices. I’ve never upgraded as the cost/benefit ratio never seemed quite worth it for my needs. At this point I look forward to buying the new unit, even if it’s expensive. I plan to use it for the next 15 years at least. You’re acting like Eventide is forcing you to upgrade, or as if there aren’t perfectly timeless used Eventides that can be picked up for way cheaper.
