Home Forums Products Rackmount H8000FW Motherboard info after battery replacement Reply To: H8000FW Motherboard info after battery replacement
#148892
    The time and date and power hours are not actually used for anything, which is why there is not a UI to set them.
    You could try running the RTC (real time clock) test. Hold down '1' at powerup,  release when asked. Turn wheel until  "(201) RTC test". Hit SELECT. When it shows P=1, hit SELECT to stop.
    This may or may not help, but these numbers don't matter.
