Home › Forums › Products › Rackmount › problems with Orville after battery replacement › Reply To: problems with Orville after battery replacement
#149000
pnordin
    electricsound wrote:
    I just performed a (very careful) battery replacement on my Orville, which was working perfectly (other than needing the battery replacement) and after powering back up it is claiming to be a DSP7000 and only allowing “Remote Operation Only”.
    I’m having the exact same issue with my Orville.  Gets to the powering on.1…100 messge, clicks twice, and screen goes blank.
    Can you share what you ended up doing to fix yours?
    Thanks,
    Paul
    I don’t have an EVE/NET and performing the power+8 reset makes no difference, which i have tried multiple times
    I did a search of the forum and the only result matches my symptoms – https://www.eventideaudio.com/community/forum/rackmount/reseviced-orville-now-dsp-7000-i-want-sent-it-you-guys-ug
    what can i do?
