Home Forums Products Rackmount H9000 – mono sum dry signal path in summed algorithm? Reply To: H9000 – mono sum dry signal path in summed algorithm?
#149004
floresp640
    Hi Ralph,
    We are so happy to hear that you recieved your H9000!
    So the issue is Mono In-Stereo Out. We are working to make this easier but as a work around right now here is what you can do:
    -Go to the Expert Router once you are in the algorithms page in the H9000.
    -You'll notice that your input 1 is only connected to one input of your loaded algorithm instead of being connected to both inputs.
    -From there, highlight the 2nd input of the loaded algorithm and press 'Add'. This will draw a connection from your Mono-in of the FX Chain to the Input 2 of your loaded algorithm.
    -This will now succesfully give you a Mono-in, Stereo-out signal flow
    Hope this helps and if you have any other questions please email me at Pflores@eventide.com and i would be happy to help!
