Home › Forums › Products › Rackmount › Can’t update H8000FW w/CF card › Reply To: Can’t update H8000FW w/CF card
June 11, 2018 at 7:17 pm
#149477
Your screenshot appears to show the contents of the .zip file.
What should be on the card (in the root directory) are the actual discrete expanded files.
If you have just copied the .zip file to the card, the H8000 will not see it, which could explain your problem.
