Reply To: Eclipse reacting inconsistently to midi cc’s
Home Forums Products Rackmount Eclipse reacting inconsistently to midi cc’s Reply To: Eclipse reacting inconsistently to midi cc’s
#149537
tmoravan
Machina wrote:
Hi there, I’m facing an issue that appears to be happening more frequently (although I may be just noticing it more) where parameters are jumping all over the place in response to incoming cc’d. For example I try to automate a level parameter by sending cc msgs every 2 beats with values increasing from 0-64 over 16 bars and this works somewhat but randomly in that period I see the level spiking way above what the cc value that is sent it and then going back down – it does this often and sometimes it’s borderline dangerous… Channels that are expected to be no louder than -30db have spikes that hit 0db which is obviously very bad… Anyone know what could be causing this?
First thing to do is to monitor the MIDI stream entering the Eclipse to verify the sending device is not the issue.
