Home Forums Products Rackmount Eclipse reacting inconsistently to midi cc’s Reply To: Eclipse reacting inconsistently to midi cc’s
#149548
I have monitored the stream and also changed the sequencer sending the stream just to make sure it isn’t that… Same problem still occurs. Also I tried slowing the tempo to check if it was a case of too many msgs arriving quickly – again this had no effect (well it had a bad effect in that when it screwed up it took longer to correct itself due to there being space between the msgs)
