Home › Forums › Products › Rackmount › Eclipse: External MIDI controllers are at 99.21% when CC value =64 › Reply To: Eclipse: External MIDI controllers are at 99.21% when CC value =64
June 27, 2018 at 2:06 pm
#149569
nickrose wrote:
More information would be good – what controllers, how are your driving them, what are you controlling, etc.
It sounds like you are trying to use a “trigger” (essentially a switch) as a controller.
Hi Nick, thanks for your answer. I am sending a series of CC events from 0 to 127, I tried both from a Midi controller and from a synth and from my step sequencer. So I can confirm that this is happening in the Eclipse and not to do with what I am sending. I tried to map ext1 to ext16 to Midi CCs.
If you don’t have any suggestions I’ll try to reinstall the OS and see if it fixes it.
