Home Forums Products Rackmount H9000-Constant crashing when sending midi program changes Reply To: H9000-Constant crashing when sending midi program changes
#149614
brysava
I’ve abandoned trying to set the unit up using scenes for my live show until that problem is fixed, and I’ve started just programing some chains to be controlled by one expression pedal and a tap tempo footswitch (mostly varying the delays). This works ok until I try to switch load a different session. When I load the session I’m generally getting consistent crashing. Once the unit reboots, and I try to load either of 2 or 3 sessions, it crashes again. The only way around this is to do a factory reboot, and reload my session from the usb thumb drive. But the crashing all starts over again if I try to load a different session.
