Home Forums Products Rackmount H9000 and emote Bugs Reply To: H9000 and emote Bugs
#150684
jbamberg
    Thank you for the reports.  We'll look into these tomorrow.
    I'm away from my H9000 at the moment, but is it possible you're seeing the tempo mode being reset because it's set to Internal (i.e. off) in the default session?  In other words, the tempo mode is stored in the session, so gets reset accordingly when the session is loaded.  When you refer to "my default session", are you referring to the factory default session, or your own session that you have saved?  In the H9000, you can't modify factory sessions, you'd have to save your own copy if you wanted to modify it.  If you know this already I apologize.  Are you loading the session via emote or using the front panel UI?
