Home Forums Products Rackmount Roland FC-300 channel select problems with Eclipse. always channel # + 1 Reply To: Roland FC-300 channel select problems with Eclipse. always channel # + 1
#151018
    Sorry for delayed reply – I had to do some research.And, I don't have an FC-300.
    But, I don't really understand your post. What do you mean by "selecting a preset, say channel 1 " or "select channel 2" ?
    Maybe when you say "channel" you mean "Program". In which case, I cannot duplicate your problem (it may be an FC-300 issue).
    The FC-300 uses banks, so to simulate it, when I want to load Program #1 I would send Bank Select 0 followed by Program Change 1. On my Eclipse, this does indeed select Program #1 (if it exists).
    Note that MIDI problems where MIDI #0 is Value #1 are pretty common, but this does not seem to be the case above.
