Home Forums Products Rackmount Emote and Apple Logic – AU Failed Validation Reply To: Emote and Apple Logic – AU Failed Validation
#151353
Racerx1492
    I had 1.0.0(47) installed when it failed. I did have a previous version prior to that.  It’s possible that the AU plugins didn’t upgrade between versions.
    I can’t check empircally as I just upgraded Emote to the public beta 1.1.4(0)  It validates fine in this new version of Emote.
    jfirlik wrote:
    Actually, the problem we were seeing was using an earlier version of Emote.  The 1.0.0[47] version fixed the validation issue, is it possible that you still have a previous version installed?  In the standalone version, hovering your mouse over the Eventide logo in the bottom right should display the actual version number.
