Home Forums Products Rackmount H9000 VSIG Support – FAQ says YES Reply To: H9000 VSIG Support – FAQ says YES
#151369
macgee
    rvickers wrote:
    I can confirm VSig is functional.  Pretty cool to not have to make any physical connection to the box as it’s done just like Emote.
    Great you have it working – I’m struggling to get VSIG to connect though.
    When you open emote, do you have to put in the physical IP of the H9k hardware or does it autoconnect?
    In my case I have to put in IP manually. On mac side it’s automatic though. And in VSIG there’s no option to specify IP of box.
    Are you doing in VM or Normal windows install?
    For network I’m using USB2 o LAN adaptor and it’s directly conncted to the VM (not through mac)
    Thanks in advance for any feedback or suggestions
