Home › Forums › Products › Rackmount › Roland FC-300 channel select problems with Eclipse. always channel # + 1 › Reply To: Roland FC-300 channel select problems with Eclipse. always channel # + 1
Sorry for delayed reply – I had to do some research.And, I don’t have an FC-300.
But, I don’t really understand your post. What do you mean by “selecting a preset, say channel 1 ” or “select channel 2” ?
Maybe when you say “channel” you mean “Program”. In which case, I cannot duplicate your problem (it may be an FC-300 issue).
The FC-300 uses banks, so to simulate it, when I want to load Program #1 I would send Bank Select 0 followed by Program Change 1. On my Eclipse, this does indeed select Program #1 (if it exists).
Note that MIDI problems where MIDI #0 is Value #1 are pretty common, but this does not seem to be the case above.
Thanks for the replay and I’m sorry it has taken me so long to get back. I did indeed mean “program” as in press pedl 1 to select program 1. I have gone to all CC mode instaed beacuse I”m primalriy using the eclipse these days as a looper in line with some of my echoplexes (yes I am a frippertronics nerd). Thanks for your looking into it and it
