Home › Forums › Products › Rackmount › Using Emote plug-in with Logic Pro X – I/O setting? › Reply To: Using Emote plug-in with Logic Pro X – I/O setting?
March 11, 2019 at 7:24 pm
#151470
That would be I
The plugin isn’t really much different. You’d still need to use I/O plugin to route audio back and forth unless I’ve missed something?
The benefit of using the plugin is that you can access automation parameters to modify algo using automation lanes and to save all session data, etc..
I’m busy making captions I’ll add to the video to explain things a bit. I’ll get it added tomorrow i reckon
