Home › Forums › Products › Rackmount › H8000FW – PCMCIA / SD Card Adapter ?? › Reply To: H8000FW – PCMCIA / SD Card Adapter ??
#151521
xmrr
    nickrose wrote:
    2-4G should be OK – above that is pretty untested.
    Ideally, use a new card and do not re-format it. Format should be FAT or FAT32, NOT exFAT or NTFS.
    Thanks for the info, i only got the CF card, cf card adapter and reader today.
    It’s a 512mb Transcend CF300 card that came fromated with FAT16, but it’s not working with the 8000.
    If i copied the files for it and do the upgrade boot up on the 8000, it just says “waiting for connection” (or similar) forever
    If i load the card in the 8000, it freezes.
    I managed to trick it into loading it on the menu to format the card, and i did try and format the card with it but said “sorry, can’t format card, possible hardware fault”.
    After this i tried re-formating in fat and do the procedure but it didn’t work, exact same behavior.
    My system is 5.3 and i would really like to ugprade it but i’m kinda lost now. Any idea how could i do this?
    Thanks in advance
