Home Forums Products Rackmount H9000 (OS 1.1) – DAW Automation, via Midi Controller, via Ableton Reply To: H9000 (OS 1.1) – DAW Automation, via Midi Controller, via Ableton
#151621
ssgrfk
    hello
    after further testing, it appears as though any midi cc data sent via automation via Ableton can crash Emote and stop the H9000 display from refreshing / updating for a few seconds in the following circumstances – draw an automation “curve” or line between 2 points, where point one is value X and point two is value Y and some time passes between these two points. playback of this = Emote crash / H9000 screen pause.
    but automation data that is simply stepped between points without any time in between moving from values does work as you would expect. so, jumping from value X to Y instantly, then remaining static for time, then jumping from Y to Z..  ie. aliased / stepped automation curve. rather than a smooth curve..
    if anyone else is having issues or success with H9000 params automatable via DAW and Ableton i would love to hear from you
    thanks
