Home › Forums › Products › Rackmount › H9000 Not Connecting to Server for Updates › Reply To: H9000 Not Connecting to Server for Updates
April 5, 2019 at 7:33 pm
#151647
Hey Ed,
How is your network connected? Please double check that your H9000 has a valid IP address under Setup > Network, and if you're using wi-fi, it's worth it to try re-connecting to see if there might be an intermittent issue. Pressing Check/Enter on the current wi-fi network will attempt to re-connect.
If all else fails, here is the offline USB installer for 1.1.5 (we're in the process of updating the links on the website)
