Home Forums Products Rackmount H9000, Morphing between presets… Reply To: H9000, Morphing between presets…
#151817
jfirlik
    Yes!  You should be able to achieve this using the Functions controls in the Parameters mode.  A Function allows you to gang together up to 8 parameters (across any algorithm within the FX chain), set independent ranges for each parameter, and then control them with a single knob.  The Function knobs can also then be controlled with MIDI or automation for real-time playability.
