Home › Forums › Products › Rackmount › H9000: 2411 – MIDIMonitor doesn’t work › Reply To: H9000: 2411 – MIDIMonitor doesn’t work
So this probably was never tested given that the text on screen still mentions Orville, but ….
I actually was curious about some MIDI info and tried to use this algorithm on the H9000. Unfortunately it doesn’t seem to be working at all.
To test that MIDI was routed properly, I assigned pitch wheel to a parameter in the Manual Flange algorithm and could see the param move as I turned the pitch wheel.
Pulling up MIDI Monitor showed no response to incoming MIDI data.
If it’s an easy fix, I’d like it updated, but if it’s really challenging, I’m sure there’s other higher priorities.
thanks
It seems to be functioning correctly for me. The output is capturing the note just as expected.
