Home Forums Products Rackmount H9000 (OS 1.1) – DAW Automation, via Midi Controller, via Ableton Reply To: H9000 (OS 1.1) – DAW Automation, via Midi Controller, via Ableton
#151910
vanceg
    I have only automated a few parameters at a time this way.  I use a method very similar to yours.  I haven’t run into the MIDI crashing issue you mention, perhaps becuase I’m only sending a little bit of MIDI data.  Perhaps someday automation will be available directly from the Emote plugin.
