Home › Forums › Products › Rackmount › H9000R Network Settings › Reply To: H9000R Network Settings
#152202
donrwatters
    How does one boot into update/failsafe mode on the H9000R?  If I’ve guessed right, then I just hold down the paperclip button hole while booting.  Unfortunately, I don’t get very far after that.  Emote crashes when I try to connect when in RECOVERY.  Since I can’t see when it’s gone through the boot process, I’m just waiting for the network light to stop blinking.
    Appendix B in the H9000 User’s Manual isn’t very helpful, since it’s only for the regular H9000.  So, I did my best here.  🙂
    It seems as though I can’t connect at all now.  Even after a reboot and trying to get in via the wifi connection or the ethernet connection.
    Here’s the WER appcrash info:
    Version=1
    EventType=APPCRASH
    EventTime=132058870035199363
    ReportType=2
    Consent=1
    UploadTime=132058871886150401
    ReportStatus=268435556
    ReportIdentifier=b9d02600-b165-4edc-8da5-baf4e7cda20a
    IntegratorReportIdentifier=9fbec196-8df2-4389-8d14-a9ccda64df77
    Wow64Host=34404
    Wow64Guest=332
    NsAppName=Emote.exe
    AppSessionGuid=00002664-0001-0015-f218-12b4d72ad501
    TargetAppId=W:0000429bc4edb5067efe64568123742ca6f40000ffff!00000e055cfeb5aa2b1b5ddefb350f53ab37efa1eb0d!Emote.exe
    TargetAppVer=2019//06//24:15:29:47!0!Emote.exe
    BootId=4294967295
    ServiceSplit=2009363780
    TargetAsId=725
    Response.BucketId=8aff0f597fd58ad0f7b25238e593bd80
    Response.BucketTable=1
    Response.LegacyBucketId=1707517613050150272
    Response.type=4
    Sig[0].Name=Application Name
    Sig[0].Value=Emote.exe
    Sig[1].Name=Application Version
    Sig[1].Value=1.1.8.2
    Sig[2].Name=Application Timestamp
    Sig[2].Value=5d10ec6b
    Sig[3].Name=Fault Module Name
    Sig[3].Value=Emote.exe
    Sig[4].Name=Fault Module Version
    Sig[4].Value=1.1.8.2
    Sig[5].Name=Fault Module Timestamp
    Sig[5].Value=5d10ec6b
    Sig[6].Name=Exception Code
    Sig[6].Value=c0000005
    Sig[7].Name=Exception Offset
    Sig[7].Value=00019e76
    DynamicSig[1].Name=OS Version
    DynamicSig[1].Value=10.0.16299.2.0.0.256.48
    DynamicSig[2].Name=Locale ID
    DynamicSig[2].Value=1033
    DynamicSig[22].Name=Additional Information 1
    DynamicSig[22].Value=e2a5
    DynamicSig[23].Name=Additional Information 2
    DynamicSig[23].Value=e2a5934c14e66921972cbe137a4819ff
    DynamicSig[24].Name=Additional Information 3
    DynamicSig[24].Value=db0d
    DynamicSig[25].Name=Additional Information 4
    DynamicSig[25].Value=db0d3763e70b9cfed2ebac71f0dca988
    UI[2]=C:Program FilesEventideEmoteEmote.exe
    UI[3]=Emote has stopped working
    UI[4]=Windows can check online for a solution to the problem.
    UI[5]=Check online for a solution and close the program
    UI[6]=Check online for a solution later and close the program
    UI[7]=Close the program
    LoadedModule[0]=C:Program FilesEventideEmoteEmote.exe
    LoadedModule[1]=C:WINDOWSSYSTEM32ntdll.dll
    LoadedModule[2]=C:WINDOWSSystem32KERNEL32.DLL
    LoadedModule[3]=C:WINDOWSSystem32KERNELBASE.dll
    LoadedModule[4]=C:WINDOWSSYSTEM32apphelp.dll
    LoadedModule[5]=C:WINDOWSSYSTEM32AcLayers.DLL
    LoadedModule[6]=C:WINDOWSSystem32msvcrt.dll
    LoadedModule[7]=C:WINDOWSSystem32USER32.dll
    LoadedModule[8]=C:WINDOWSSystem32win32u.dll
    LoadedModule[9]=C:WINDOWSSystem32GDI32.dll
    LoadedModule[10]=C:WINDOWSSystem32gdi32full.dll
    LoadedModule[11]=C:WINDOWSSystem32msvcp_win.dll
    LoadedModule[12]=C:WINDOWSSystem32ucrtbase.dll
    LoadedModule[13]=C:WINDOWSSystem32SHELL32.dll
    LoadedModule[14]=C:WINDOWSSystem32cfgmgr32.dll
    LoadedModule[15]=C:WINDOWSSystem32shcore.dll
    LoadedModule[16]=C:WINDOWSSystem32RPCRT4.dll
    LoadedModule[17]=C:WINDOWSSystem32SspiCli.dll
    LoadedModule[18]=C:WINDOWSSystem32CRYPTBASE.dll
    LoadedModule[19]=C:WINDOWSSystem32bcryptPrimitives.dll
    LoadedModule[20]=C:WINDOWSSystem32sechost.dll
    LoadedModule[21]=C:WINDOWSSystem32combase.dll
    LoadedModule[22]=C:WINDOWSSystem32windows.storage.dll
    LoadedModule[23]=C:WINDOWSSystem32advapi32.dll
    LoadedModule[24]=C:WINDOWSSystem32shlwapi.dll
    LoadedModule[25]=C:WINDOWSSystem32kernel.appcore.dll
    LoadedModule[26]=C:WINDOWSSystem32powrprof.dll
    LoadedModule[27]=C:WINDOWSSystem32profapi.dll
    LoadedModule[28]=C:WINDOWSSystem32OLEAUT32.dll
    LoadedModule[29]=C:WINDOWSSystem32SETUPAPI.dll
    LoadedModule[30]=C:WINDOWSSYSTEM32MPR.dll
    LoadedModule[31]=C:WINDOWSSYSTEM32WINSPOOL.DRV
    LoadedModule[32]=C:WINDOWSSYSTEM32IPHLPAPI.DLL
    LoadedModule[33]=C:WINDOWSSYSTEM32bcrypt.dll
    LoadedModule[34]=C:WINDOWSSYSTEM32sfc.dll
    LoadedModule[35]=C:WINDOWSSYSTEM32sfc_os.DLL
    LoadedModule[36]=C:WINDOWSSystem32IMM32.DLL
    LoadedModule[37]=C:WINDOWSSystem32COMDLG32.dll
    LoadedModule[38]=C:WINDOWSSYSTEM32WINMM.dll
    LoadedModule[39]=C:WINDOWSSystem32ole32.dll
    LoadedModule[40]=C:WINDOWSWinSxSx86_microsoft.windows.common-controls_6595b64144ccf1df_5.82.16299.1087_none_3edce3bab923e35cCOMCTL32.dll
    LoadedModule[41]=C:WINDOWSSystem32WS2_32.dll
    LoadedModule[42]=C:WINDOWSSYSTEM32WINMMBASE.dll
    LoadedModule[43]=C:WINDOWSSYSTEM32WININET.dll
    LoadedModule[44]=C:WINDOWSSYSTEM32MSVCP140.dll
    LoadedModule[45]=C:WINDOWSSYSTEM32VCRUNTIME140.dll
    LoadedModule[46]=C:WINDOWSSYSTEM32dnssd.dll
    LoadedModule[47]=C:WINDOWSsystem32uxtheme.dll
    LoadedModule[48]=C:WINDOWSSystem32MSCTF.dll
    LoadedModule[49]=C:WINDOWSsystem32dwmapi.dll
    LoadedModule[50]=C:WINDOWSSYSTEM32CLDAPI.dll
    LoadedModule[51]=C:WINDOWSSYSTEM32FLTLIB.DLL
    LoadedModule[52]=C:WINDOWSSYSTEM32AEPIC.dll
    LoadedModule[53]=C:WINDOWSSYSTEM32ntmarta.dll
    LoadedModule[54]=C:WINDOWSSYSTEM32cryptsp.dll
    LoadedModule[55]=C:WINDOWSSystem32clbcatq.dll
    LoadedModule[56]=C:WINDOWSsystem32propsys.dll
    LoadedModule[57]=C:WINDOWSWinSxSx86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.16299.1087_none_573dab8d6ee1b2bdcomctl32.dll
    LoadedModule[58]=C:WINDOWSSYSTEM32WindowsCodecs.dll
    LoadedModule[59]=C:WindowsSystem32thumbcache.dll
    LoadedModule[60]=C:WINDOWSsystem32dataexchange.dll
    LoadedModule[61]=C:WINDOWSsystem32dcomp.dll
    LoadedModule[62]=C:WINDOWSsystem32d3d11.dll
    LoadedModule[63]=C:WINDOWSsystem32dxgi.dll
    LoadedModule[64]=C:WINDOWSsystem32twinapi.appcore.dll
    LoadedModule[65]=C:WINDOWSsystem32RMCLIENT.dll
    LoadedModule[66]=C:WINDOWSsystem32mswsock.dll
    LoadedModule[67]=C:WINDOWSSystem32TextInputFramework.dll
    LoadedModule[68]=C:WINDOWSSystem32CoreUIComponents.dll
    LoadedModule[69]=C:WINDOWSSystem32CoreMessaging.dll
    LoadedModule[70]=C:WINDOWSSYSTEM32wintypes.dll
    LoadedModule[71]=C:WINDOWSSYSTEM32mscms.dll
    LoadedModule[72]=C:WINDOWSSYSTEM32USERENV.dll
    State[0].Key=Transport.DoneStage1
    State[0].Value=1
    OsInfo[0].Key=vermaj
    OsInfo[0].Value=10
    OsInfo[1].Key=vermin
    OsInfo[1].Value=0
    OsInfo[2].Key=verbld
    OsInfo[2].Value=16299
    OsInfo[3].Key=ubr
    OsInfo[3].Value=1087
    OsInfo[4].Key=versp
    OsInfo[4].Value=0
    OsInfo[5].Key=arch
    OsInfo[5].Value=9
    OsInfo[6].Key=lcid
    OsInfo[6].Value=1033
    OsInfo[7].Key=geoid
    OsInfo[7].Value=244
    OsInfo[8].Key=sku
    OsInfo[8].Value=48
    OsInfo[9].Key=domain
    OsInfo[9].Value=0
    OsInfo[10].Key=prodsuite
    OsInfo[10].Value=256
    OsInfo[11].Key=ntprodtype
    OsInfo[11].Value=1
    OsInfo[12].Key=platid
    OsInfo[12].Value=10
    OsInfo[13].Key=sr
    OsInfo[13].Value=0
    OsInfo[14].Key=tmsi
    OsInfo[14].Value=73097
    OsInfo[15].Key=osinsty
    OsInfo[15].Value=3
    OsInfo[16].Key=iever
    OsInfo[16].Value=11.1087.16299.0-11.0.120
    OsInfo[17].Key=portos
    OsInfo[17].Value=0
    OsInfo[18].Key=ram
    OsInfo[18].Value=32675
    OsInfo[19].Key=svolsz
    OsInfo[19].Value=1042
    OsInfo[20].Key=wimbt
    OsInfo[20].Value=0
    OsInfo[21].Key=blddt
    OsInfo[21].Value=180808
    OsInfo[22].Key=bldtm
    OsInfo[22].Value=1748
    OsInfo[23].Key=bldbrch
    OsInfo[23].Value=rs3_release
    OsInfo[24].Key=bldchk
    OsInfo[24].Value=0
    OsInfo[25].Key=wpvermaj
    OsInfo[25].Value=0
    OsInfo[26].Key=wpvermin
    OsInfo[26].Value=0
    OsInfo[27].Key=wpbuildmaj
    OsInfo[27].Value=0
    OsInfo[28].Key=wpbuildmin
    OsInfo[28].Value=0
    OsInfo[29].Key=osver
    OsInfo[29].Value=10.0.16299.1087.amd64fre.rs3_release.180808-1748
    OsInfo[30].Key=buildflightid
    OsInfo[31].Key=edition
    OsInfo[31].Value=Professional
    OsInfo[32].Key=ring
    OsInfo[33].Key=containerid
    OsInfo[34].Key=containertype
    OsInfo[35].Key=edu
    OsInfo[35].Value=0
    FriendlyEventName=Stopped working
    ConsentKey=APPCRASH
    AppName=Emote
    AppPath=C:Program FilesEventideEmoteEmote.exe
    NsPartner=windows
    NsGroup=windows8
    ApplicationIdentity=B21CBB63D3956E978DFF75308415EFCD
    MetadataHash=1668642302
