Home › Forums › Products › Rackmount › Is the H9000 D-sub AES/EBU connector Tascam or Yamaha pinout? › Reply To: Is the H9000 D-sub AES/EBU connector Tascam or Yamaha pinout?
#152544
jfirlik
    I don't think this is possible directly — they use the same connector but the AES format is incompatible with TDIF.  Tascam at one point made a converter box (IF-AE8) which should theoretically work if you can get your hands on one, but your mileage may vary.
