Home Forums Products Rackmount Eclipse Knob Reply To: Eclipse Knob
#152817
gregsinibaldi
    That sounds an awful lot like I’ll LOSE ALL MY PRESETS! Which is what I was trying to avoid in the beginning. Should I make another attempt to back my presets up to a card before I do the following per the manuaual:
    If this does not resolve the problem, power down and then power back up while holding down the SETUP key. After a few seconds, the Eclipse will ask if you want to “return to factory defaults.” Select <YES> – this will fix almost all problems, but will require you to re-enter any SETUP values that you have changed. It will NOT erase any programs that you have saved.
    Greg
